Datasheet Texas Instruments TRF3761-JIRHAT — Даташит
Серия | TRF3761-J |
Модель | TRF3761-JIRHAT |
Малошумный синтезатор частоты PLL целого числа n со встроенным ГУН 40-VQFN от -40 до 85
TRF3761-x Integer-N PLL with Integrated VCO datasheet
PDF, 2.5 Мб, Версия: K, Файл опубликован: 31 дек 2015
Купить TRF3761-JIRHAT на РадиоЛоцман.Цены — от 636 до 79 423 ₽ 15 предложений от 11 поставщиков Integer-N Synthesizer/VCO IC 2.3GHz 1 40-VFQFN Exposed Pad | |||
TRF3761-JIRHAT Texas Instruments | 636 ₽ | ||
TRF3761-JIRHAT Texas Instruments | 1 164 ₽ | ||
TRF3761-JIRHAT | по запросу | ||
TRF3761-JIRHAT Texas Instruments | по запросу |
Pin | 40 | 40 |
Package Type | RHA | RHA |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | -J | TRF3761 |
Width (мм) | 6 | 6 |
Length (мм) | 6 | 6 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
Current Consumption | 130 мА |
Integrated VCO | Yes |
Lock Time(Typ) | >350 us |
Normalized PLL Phase Noise | -137 dBc/Hz |
Output Frequency(Max) | 2295 МГц |
Output Frequency(Min) | 2140 МГц |
Package Size: mm2:W x L | 40VQFN: 36 mm2: 6 x 6(VQFN) PKG |
Rating | Catalog |
Special Features | Integrated VCO |
VCC | 4.5 to 5.25 В |
VCO Phase Noise(Nom) | -136 dBc/Hz |
- TRF3761 QFN Installation Using a Hakko Hot Air Rework StationPDF, 38 Кб, Файл опубликован: 7 апр 2007
The TRF3761 devices are typically sampled separately from the board provided. This guideline is designed to help the user evaluating these parts install the sample device. - Fractional/Integer-N PLL BasicsPDF, 6.7 Мб, Файл опубликован: 13 май 1998
Phase Locked Loop (PLL) is a fundamental part of radio, wireless and telecommunication technology. The goal of this document is to review the theory, design and analysis of PLL circuits. PLL is a simple negative feedback architecture that allows economic multiplication of crystal frequencies by large variable numbers. By studying the loop components and their reaction to various noise sources, we
Серия: TRF3761-J (1)
- TRF3761-JIRHAT
- Semiconductors > Clock and Timing > RF PLLs and Synthesizers
TRF3761JIRHAT, TRF3761 JIRHAT
