Datasheet Diodes AP22815 — Даташит
Производитель | Diodes |
Серия | AP22815 |
3.0a Single Channel Power Distribution Switch With Output Ovp
Купить AP22815 на РадиоЛоцман.Цены — от 27 до 4 356 ₽ 19 предложений от 10 поставщиков IC: power switch; high-side,USB switch; 3А; Ch: 1; P-Channel; SMD | |||
AP22815BWT-7 Diodes | 27 ₽ | ||
AP22815BWT-7 Diodes | 28 ₽ | ||
AP22815BWT | 74 ₽ | ||
AP22815AWT7 | 4 356 ₽ |
The AP22815/615 is a 3A/Adjustable single channel current-limited high-side power switch with output OVP optimized for USB and other hot-swap applications which need to have over voltage protection from output to protection the system.
The AP22815/615 complies with USB standards and is available with both polarities of Enable input. AP22815 supports fixed current-limited feature, while AP22615 equips adjustable current-limited feature optimized for applications that require precision current limiting support. It supports USB PD3.0 fast role swap function. The output voltage could recovery to USB valid voltage range within 110us during USB PD fast role swap event.
AP22815AWT-7 | |
N | 1 |
Корпус | TSOT25 |
Parameters / Models | AP22815AWT-7 |
Enable Logic | Active High |
Maximum Continuous Output Current | 3 A |
Maximum Current Limit | 4.2 A |
Maximum Operating Voltage | 5.5 V |
Minimum Operating Voltage | 3 V |
NEMKO IEC 60950-1 CB | Yes |
OCP Flag | Yes |
OCP Output Latch Off | No |
Operating Ambient Temperature Range | -40 to 85 °C |
Output Discharge | Yes |
Quiescent Current Typ | 300 µA |
RDS(ON) (VIN = 5V) Typ | 40 mΩ |
UL Listed | Yes |
- Power Management > Protected Switches > USB Switches > Single Channel USB Switch
