Datasheet Diodes PI4ULS5V108ZBAEX — Даташит
ПроизводительDiodes
СерияPI4ULS5V108
МодельPI4ULS5V108ZBAEX
8-Bit Bi-Direction Level Shifter for Open-Drain and Push-Pull Application
Datasheet
PDF, 1.3 Мб, Файл закачен: 19 дек 2018
15 предложений от 8 поставщиков
8-Bit Bi-Directional Level Shifter For Open-Drain And Push-Pull Application
PI4ULS5V108ZBAEX
Diodes
47 ₽
PI4ULS5V108ZBAEX
Diodes
49 ₽
Utmel
PI4ULS5V108ZBAEX
Diodes
от 180 ₽
FAV Technology
PI4ULS5V108ZBAEX
Diodes
Электромеханические реле Hongfa – надежность и качество 19 января 2023
The PI4ULS5V108 supports up to 100 MHz up translation and greater than 100 MHz down translation at <= 30pF cap load and up to 40 MHz up/down translation at 50pF cap load which allows the LSF family to support more consumer or telecom interfaces (MDIO or SDIO).
It has bidirectional voltage translation without the need for DIR pin which minimizes system effort (for PMBus, I2C, or SMbus).
The PI4ULS5V108 supports 5 V tolerance on IO port which makes it compatible with TTL levels in industrial and telecom applications. It is able to set up different voltage translation levels on each channel which makes it very flexible.
КорпусTSSOP (L20) MSL1 Sn
Auto Direction Sensing?No
Bits Needed8
Max Signal Rate100Mhz
Prop Delay2.2ns
ShiftBi-Directional
Temperature-40 to 125
Translation From (V)0.95 to 3.3
Translation To (V)1.8 to 5
Серия: PI4ULS5V108 (1)
  • PI4ULS5V108ZBAEX
  • Connectivity & Timing > Interface > Universal Level Shifter / Voltage Translation (ULS)
На английском языке: Datasheet Diodes PI4ULS5V108ZBAEX
