Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheets - Схемы синхронизации - 3
Подраздел: "Схемы синхронизации"
Производители
Analog Devices Diodes IDT
Найдено: 369 Вывод: 41-60
Вид: Список / Картинки
  1. Very Low Power 4-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33402 is a four-output very-low power PCIe Gen1/Gen2/ Gen3/ Gen4/ Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz ...
  2. Very Low Power 4-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33402 is a four-output very-low power PCIe Gen1/Gen2/ Gen3/ Gen4/ Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz ...
Электромеханические реле Hongfa – надежность и качество 19 января 2023
  2. Very Low Power 6-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33602C is a 6-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power ...
  1. Very Low Power 6-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33602C is a 6-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power ...
  2. Very Low Power 2-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33202C is a 2-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power ...
  3. Very Low Power 2-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33202C is a 2-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power ...
  4. Pci Express (pcie) Clock Generators The PI6CG33801C is an 8-output very low power PCIe Gen1/Gen2/ Gen3/ Gen4/ Gen 5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power differential HCSL outputs with ...
  5. Very Low Power 6-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33601C is a 6-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power ...
  6. Very Low Power 4-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33402C is a four-output very-low power PCIe Gen1/Gen2/ Gen3/ Gen4/ Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz ...
  7. Very Low Power 2-OUTPUT Pcie Clock Generator With On-Chip Termination The PI6CG33201C is a 2-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator. It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power ...
  8. MicroClock Programmable Clock Generator The 5L2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices. The 5L2503 device is a 3 PLL architecture design. Each PLL is individually ...
  9. MicroClock Programmable Clock Generator The 5L2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices. The 5L2503 device is a 3 PLL architecture design. Each PLL is individually ...
  10. MicroClock Programmable Clock Generator The 5L2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices. The 5L2503 device is a 3 PLL architecture design. Each PLL is individually ...
  11. MicroClock Programmable Clock Generator with Embedded Crystal The 5X2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices. The 5X2503 device is a 3 PLL architecture design with an ...
  12. MicroClock Programmable Clock Generator with Embedded Crystal The 5X2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices. The 5X2503 device is a 3 PLL architecture design with an ...
  13. MicroClock Programmable Clock Generator with Embedded Crystal The 5X2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices. The 5X2503 device is a 3 PLL architecture design with an ...
  14. MicroClock Programmable Clock Generator The 5L1503 is a series of small form factor programmable clock generators intended for low-power, consumer, battery powered applications, wearable and smart devices. The device is a 1 PLL + DCO architecture ...
  15. MicroClock Programmable Clock Generator The 5L1503 is a series of small form factor programmable clock generators intended for low-power, consumer, battery powered applications, wearable and smart devices. The device is a 1 PLL + DCO architecture ...
  16. MicroClock Programmable Clock Generator The 5L1503 is a series of small form factor programmable clock generators intended for low-power, consumer, battery powered applications, wearable and smart devices. The device is a 1 PLL + DCO architecture ...
